I
AGraham
Message 2 of 2
I've just received a new router and set it up but now I can't connect to my sky box or Alexa. What do I need to do
1 REPLY 1
Message 1 of 2
You may need to reconnect to the wifi with your devices, often it is usually easier to log into the new router and change the wifi SSID (name and password) to the same as your old router.  This way your devices should connect.
