IPC 6023
3 REPLIES 3
fre55die
Hi @OCE_Karl
I have been struck by the dreaded 6023 problem. No BOOST channels. I have left router off all night and done all of the usual things. I have swapped primary boxes as well still getting either 6023 or 6017 errors. Boxes all showing connected and speed 37.06 Down 6.60 up from computer hard wired. I can play recordings from boost channels. This is on Two Humax and One Huawei box.
I can play from MORE TV my stuff.
Help
OCE_Karl
I've passed this over to Rez in TV to kick the back end and see if anything falls out.
fre55die
Thanks Karl. I obviously lost phone connection at some stage overnight as Alarm was beeping with message "phone connection error" earlier.
OCE_Karl
No Problem 🙂
i'll let you know as soon as i get a reply.
