27-01-2022 10:54 PM - edited 27-01-2022 10:55 PM
I've had this issue before and assumed it's down to the transmission. But it's started to get very irritating particularly on ITV hub. I've done a search on here and there's a lot of historical references to the problem and no apparent solution.
What happens is that during an ad that is probably the last before rejoining the program, the screen freezes.
The symptoms are similar to loosing broadband.
It needs a manual pause and then an enter, perhaps a few times and it then restarts.
As the problem was raised a number of years ago, there must be an answer by now?
Any help ????
on 02-02-2022 07:58 AM
We do believe this to be the app itself as it is also prevalent across other youview box models.
on 28-01-2022 05:52 PM
@des09 A Google search also shows that the problems extend to many platforms including their own website online.
on 28-01-2022 05:23 PM
Thanks for that. I suppose it was always likely to be the actual provider.
I'll check more carefully over the next days and weeks and see if it still occurs using the Samsung app on the TV. If it does it at least clears TT.
It doesn't bode well about getting it fixed either way, as any search on the subject goes back years. Thanks anyway.
on 28-01-2022 03:26 PM
The ITV Hub is notorious for this kind of behaviour, how thoughtful of them to breakdown during the programme, but not the adverts!
For anybody seeing this behaviour it is best to note time and channel/programme details and refer it directly to ITV:
28-01-2022 03:13 PM - edited 28-01-2022 03:30 PM
Hi @des09
Well curiously now. I've been trying it out again by playing full hour long shows from the "hub" on my Humax YV box (a retail box not supplied by TT using completely different software and firmware) again, my Netgem box and my ROKU box all played right through with no sign of the problem on any of them. My SMART TV is Sony and doesn't have the ITV app on it.
Very annoying. I shall perservere.
on 28-01-2022 11:54 AM
I don't the answer to this, perhaps you do. If you have a smart tv, with apps, does it happen on there too?
I haven't tested it and frankly can't remember either way.
Of course if it does happen on smart tv it's not a TT problem. Perhaps anyone else reading this might know.
28-01-2022 02:20 AM - edited 28-01-2022 02:22 AM
Mine is exactly the same, the Skipton BS are certainly getting their moneys worth!!
I am using a Humax T2000 so it's an ITV hub or YV issue rather than just a Huawei problem. The back button often works for me.
