ITV player has never worked properly - needs updating
ken01
Whizz Kid
Message 6 of 6
Hi the itv player on demand, sticks on the 2nd set of adverts and has to be closed. Every single time without fail. It’s done this on all 3 Talktalk tv boxes I’ve owned. I contacted itv regarding this, they told me at first they knew about this issue and fixed it with an update and I should update the software. As I had just done that it turns out the TalkTalk freeview boxes haven’t taken any of the updates for a very long time so I’m stuck on old software which doesn’t work. They told me to contact TalkTalk regarding getting the TV box to accept a newer update to fix the issue. As it stands I still can’t use the itv player.  There has been several updates to the ITV player and the current software I’m stuck in is very old.
Ive pasted the last email I received from ITV technical support for reference below.
can this be looked into please?
thanks
Ken
Hi Ken,
I am sorry to hear that you are still experiencing the problem.
Thank you for sending us the ITV Hub information screen and update screens from your box. From checking these details I can see that you are currently on ​the component software 3.7.54.
On Youview's support page it does appear to be a more recent version made available on the 13th April 2021.
It seems that your box has not picked up the update as of yet, despite your box showing that the last checked for updates was the 30th.
On Youview's support page it does mention that this is a phased software release therefore some boxes will receive this update before others, so it may take a while for the update to reach you I'm afraid. For further guidance on the timeframes, I would advise contacting Youview or TalkTalk as this is out of our control.
https://support.youview.com/youview-box/software-updates/talktalk-software-update-60-48-91-and-72-48...
Kind regards,
ITV Customer & Viewer Services
5 REPLIES 5
Message 1 of 6
We can try a box swap, but this would be for a non recording box as TalkTalk no longer supply a recording box.
would you like to try this ?
ken01
Whizz Kid
Message 2 of 6
I’ve done the lot Karl. Update players and apps, and then a full reset. Twice as the boxes hard drive failed as well.
Still it does not update past the current software version.? Do other TalkTalk tv customers have this issue?
Message 3 of 6
Then I would try the full factory reset from the settings menu and set the box up from scratch and see what happens.
ken01
Whizz Kid
Message 4 of 6
It does not work, the itv player doesn’t update past the version it already is.
Message 5 of 6
Hi Ken,
Try a Youview Maintenance Reset  and see if this then downloads the correct version.
