on 30-12-2020 07:22 PM
When I want to use the apps such as iPlayer or Netflix after about 30 minutes it kicks me out, I’ve also started getting this issue with my recordings. Is there a way to fix this?
on 31-12-2020 07:28 AM
Hi Bekki94
Try the reset procedure as advised and let me know if this helps.
on 30-12-2020 08:04 PM
These are 2 separate issues and the following steps may help resolve them.
The full factory reset my be required for the recordings issue if the keep recordings reset does not work.
Work through these in order.
Have you tried a soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart. Alternatively, you can turn off from the back and power back on.
If this doesn’t work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu. You will lose your recordings but you may be asked to do this before the OCE look at other alternatives.
Hope it works but if not then please let us know and I’ll flag for further assistance.
