Itv hub and channel 4
DottyLS
Message 3 of 3
I have the basic package from talk talk but only have BBC iPlayer in the apps. I expected I would also get itv hub and the channel 4 app. Is there a way I can download these?
I need the apps as I don't have a tv aerial so I can't watch the freeview channels live.
I have already tried a factory reset of the box but didn't make any difference.
Thank you!
Message 1 of 3
Hi DottyLS
ferguson is correct, some regional apps need an aerial connected to work as they use the freeview signal to identify your region and deliver the correct content.
Message 2 of 3
You need to connect and tune in an aerial to get ITV and Channel 4 apps as they are regionally specific and need to be registered over the air. Can you maybe not try with an indoor aerial?
