Itv hub not playing
revkim
Message 28 of 28
Help please. I can load itvhub app, select a programme but will not play - freezes on itv more than TV screen with scrolling balls. Unit is dn372t. Have done factory reset but made no difference. Other apps ok
27 REPLIES 27
Message 1 of 28
Thanks for the update 🙂
Message 2 of 28
Hi. Working now. Thanks for your help.
Message 3 of 28
Returning the new box will be ok.
Message 4 of 28
Hi. I received another return envelope and label today. However I have already returned the new box using the envelope and label that came with it. Hope this is OK. Kim
Message 5 of 28
Many thanks for keeping me updated. Kim
Message 6 of 28
i reported this to YouView and they have already raised an issue to ITV and awaiting a response.
you can monitor progress here on their forum.
https://community.youview.com/youview/discussion/7606770/itv-hub-unavailable-on-1st-gen-youview-devi...
Message 7 of 28
Thanks for the advice
Message 8 of 28
Message 9 of 28
Totally agree with @fre55die, it is far more likely to be an ITV Hub issue. You would do better to keep your recording box if it is otherwise working OK and return the replacement non-recording box.
Message 10 of 28
Hi @revkim
I should return the new lite box that @Karl-TalkTalk  has just sent you and keep the recording box if I were you. You are not alone with ITV Hub problems, I often get problems with it using other devices as well. Whilst not identical very similar problems here : https://community.talktalk.co.uk/t5/TV/ITV-hub-ads-sticking/m-p/2855378#M178561
Also the results of a Google search https://www.google.com/search?client=firefox-b-d&q=problems+with+the+itv+hub
Message 11 of 28
Received today thanks Karl. Sadly there's the same problem!!  😞 itv hub works fine on my  phone. Shall I return the new box so I keep the record function?
Message 12 of 28
It's on the way.
Message 13 of 28
Thanks then please go ahead with the swap
Kim
Message 14 of 28
You can still pause / rewind live TV.
Message 15 of 28
Is there still a pause facility?
revkim
Message 16 of 28
Xx
Message 17 of 28
I can swap this out however this will be for the DN360T model as we no longer provide the recordable boxes, would you like me to send this ?
Message 18 of 28
No, no change I'm afraid Thanks
Message 19 of 28
Hi revkim
Did the reset help ?
Message 20 of 28
Hi. Thanks for your suggestion. Yes the box is connected directly to the router. I'll give it another reset as soon as I get a a chance. Kim
