Lost all channels
Mollyrushforth
Message 5 of 5
Worked absolutely fine until this morning, I have no channels to watch when I go on my guide. I have tried retuning and it only finds 1 channel. I have checked all the cables and the aerial and rebooted the box twice and still nothing
4 REPLIES 4
Message 1 of 5
So there are no channels showing on the TV with the aerial connected directly to the TV ?
Mollyrushforth
Message 2 of 5
Doesn’t work
Message 3 of 5
Hi Mollyrushforth
Did you try the aerial at the TV as advised ?
Message 4 of 5
What happens if you plug the aerial directly into the TV and bypass the box? Do you get channels there after a retune?
If not, then it's an aerial issue and you will need to contact a local installer.
If you get channels on the TV but still not through the box, please let us know.
