Lost channels after fibre upgrade
Bluemoon1
Message 8 of 8
I have had a fibre upgrade today. However i have now lost access to all my boost channels. It’s the same problem that vickyb17uk posted a few minutes ago with exactly the same error messages. My broadband is fine with a speed of 32mbps.
An engineer has been booked for 8 days time but is there anything you can do to fix this before then.
i have completed a factory reset but no luck.
7 REPLIES 7
Message 1 of 8
Glad to hear the channels have been restored.
Message 2 of 8
I should have more patience! I can see all channels now. Thanks for your help.
Message 3 of 8
Hi Karl
Any update as I still cannot get the tv boosts?
Message 4 of 8
Hi Karl
Nothing has changed yet but I appreciate there is a long queue. Just thought I would let you know that I have now lost BT Sport that was available.
Andy
Message 5 of 8
No Problem 🙂
The issue itself is relatively quick to fix, just depends how many faults the team are looking at today and how soon your issue gets to the top of their que.
Message 6 of 8
Brilliant Karl thank you.
Message 7 of 8
I can see what the problem is.  I've raised this to my TV Colleagues to correct the reference in the back end database.  Should not be to long.
