Lost internet channels after fibre upgrade
vickyb17uk
Message 7 of 7
Have been upgraded to fibre today. Internet itself works fine however have seemed to have lost internet channels with the ip6017 error. I then get click on a channel that is only available through boost, it will state "To watch this channel you'll need to set it up. Press OK".
I press OK and it states "loading", then it gets to a page where it says "TV boosts are not available.  Your account does not allow you to add extra TV channels". However going in to my account on the internet the boost is showing as there.
Done the box reset and not helped
6 REPLIES 6
Message 1 of 7
No Problem 🙂
Glad to help.
Message 2 of 7
Just to let you know issue has now been resolved. Thank you so much for your help
Message 3 of 7
Hi vickyb17uk
This should be resolved now, can you retest and let me know.
Message 4 of 7
No Problem 🙂
The issue itself should not take long to fix, just depends on how many fault tickets the team are dealing with before your ticket gets to the top of their que.
Message 5 of 7
Hi thanks so much for looking.
Message 6 of 7
Hi vickyb17uk
i can see the problem.
I've raised this to my TV colleagues to correct the issue with the back end database.
