Missing some channels
magicman4757
Hi could some one help me My wife has told me we have lost about ten channels qvc being to her the most important but i have tried everything i can and they are gone i don't know what to do she like to record thing or i would just use freeview it works fine anyone help and i have retuned everything a million times.
Try removing the aerial from the box and do a retune. This will obviously result in zero channels available, but will also clear the tuner memory, Then reconnect the aerial and retune again, see if that helps.
OCE_Karl
Hi magicman4757
did you try the retune process as advised ?  Did this help ?
