More TV error message TTG-117
wildcat_tighness
Message 4 of 4
I can't get More TV to work - tried several months ago, gave up and tried again this week - still no luck. If I press the YouView button then i get a message saying "There was a problem authenticating [TTG-117]" - but this isn't on the list of error codes so I can't look it up. Have seen similar threads here and tried turning off router, turning off youview box - no luck. If I press TalkTalk button then I get the same message. Any ideas? Would like to be able to access this part of our package!
3 REPLIES 3
Message 1 of 4
Glad I've been able to help.
Message 2 of 4
Hi @Karl-TalkTalk
Thank you! That has worked. 😃
(I wish now that I had posted about this here months ago! 😣)
Best wishes
Lauren
Message 3 of 4
All TV settings look ok.  I've removed the registered TV boxes from the system.
Can you try a Youview Maintenance Reset (Option 2: Keep Recordings).
Set the TV Box back up and this will re-register the box, then test More TV again and see if the same error occurs.
