Movie Rental (Error Code TTG-250)
tickety boo
Message 4 of 4
Hi, I have the error code TTG-250 for a film I ordered using the free voucher. I have tried re-booting the box & internet several times to no effect. I have 3 hours to resolve this problem before it times out. I would be most grateful if someone can resolve the issue as I can't find a way to actually speak with TalkTalk.  Apologies to Karl and Gliwmaeden2 (afraid I'm a novice at this). Best Regards.
3 REPLIES 3
Message 1 of 4
I've unregistered the boxes for some customers to allow the box to re-register, but not heard back to confirm if it has helped.
I'm also not seeing any issues with their connections.   I do know that around the 21st there were some major outages in parts of the country affecting multiple providers as a result of the weather, but cannot confirm if this has impacted those individual connections.
tickety boo
Message 2 of 4
Hi Karl, the box is connected to the internet via a cable. There has been no problem connecting the box to the internet from 21st as I have accessed the movie rental site several times in the interim (to see if the fault had been rectified). I have also been able to record and replay several TV programmes using the box. The fault is only with movie rentals. I notice several people have experienced the same problem so assume the fault is the same. Could you confirm the fault has been solved yet please. Best Regards.
Message 3 of 4
I'm showing the box has been having difficulty connecting to the internet as I'm showing a connection log for the 21st, then nothing until the early hours of this morning.
Is the box connected via a cable or via powerline adapters ?
