Much reduced volume on tv
Predator55
Message 4 of 4
Received new replacement youview box and set up correctly. Now only able to hear TV if volume turned up to nearly max 60, before I only turned volume up to 26. Recordings are even quieter. I believe there is a fault with the box as I never had this trouble with the old one. Can someone at talktalk advise or arrange for new box to be sent please?
3 REPLIES 3
Message 1 of 4
As when you first got the remote, you will need to enter the relevant code for the TV.
https://community.talktalk.co.uk/t5/Articles/TalkTalk-Remote-Control-Guide/ta-p/2204370
Message 2 of 4
Thanks Karl. Much better volume, need to have TV vol up to max and control vol through remote control via Youview box 0-100%. Problem now is that Remote won't turn TV on and off as it used to, so I have to use the old tv remote as well. How do I rectify this. Thanks.
Message 3 of 4
Did you turn the volume up to 100% on the TV box ?
On remote,
Press 1 & 6 together for 3 seconds – Red LED turns on.
Enter code : 9 8 1
This resets remote to control YouView Box, turn the volume to 100%.
