Multi Room - play recorded programs/films
grizza1
Message 4 of 4
Hi.  I read that I would be able to pause and rewind on the multi room box.
I just want to make sure I can play back any recorded programs too, and even set recodings from this exra box.
I'm also assuming the recodings sit in the main box.
Can anyone or owners confirm please?
Dave
3 REPLIES 3
Message 1 of 4
You can play the recordings from the main box, just not from the secondary box.   If you use a long cable as you describe, this should work 🙂
Message 2 of 4
Thanks Karl.  Will I be able to access the recordings and play them through the multi room box ?
At the moment I have a 20ft HDMI flat lead under carpets to my study to effect a 'multi room'  equivalent but have to use a ebode transmitter set up to have enable a remote control in the study.Not ideal but works, just about.
Message 3 of 4
All recordings will sit on the main box with multiroom as the secondary box supplied does not contain a hard drive and has no record functionality.
