Multiroom self set up
Dstewart2205
Message 8 of 8
Hi folks, sorry if I'm dragging up an already asked question. If I've got two talktalk tv boxes, means to connect second box to the Internet (I put an ethernet point in every room at one point) then how do I get both boxes activated for boost channels other than an engineer visit? Can this be done remotely as I would rather do it this way given the whole covid situation as my partner cares for her elderly grandmother so were still being overly careful. Many thanks for any responses, David.
7 REPLIES 7
Message 1 of 8
If you select one of the boost channels on the other box, then select ok it it asks to make that box the main one, do the channels then work across both boxes.
Dstewart2205
Message 2 of 8
Yes the other box is still working on standard channels but only one box will allow boosts channels to be used. Many thanks, David.
Message 3 of 8
If you select one of the boxes as the main box, the other will usually work also
Dstewart2205
Message 4 of 8
No problem i currently have kids and entertainment boosts active since the beginning of the contract, the main thing I am wondering is if I put a second box in the house it is asking me to choose a main box rather than running a multiroom set up as such, the "second" box will only run basic channels. I am wanting to have my active boosts available on both boxes. I hope that explains it a bit better. Many thanks, David.
Message 5 of 8
If you already have the boost added it will continue until removed, if you do not currently have the boost it cannot be added.
Sorry if this is not what you meant, I thought you were asking about adding the boost.
Dstewart2205
Message 6 of 8
Thanks for the reply Karl, I am aware these are due to end but would i be right to assume I will continue receiving these channels until the end of my contract? I've still got a year left to run. Many thanks, David.
Message 7 of 8
Hi David,
Boost channels are no longer available for new or existing customers and these will all stop at some point in the future.
You can access Now TV via the app on the box if they are connected to the internet.
