My Talktalk box stopped working, how can I get a replacement?
fbeglis
Message 3 of 3
Message 1 of 3
Hi fbeglis
Can you please add your home phone number to your 'Community Profile' so I can pick this up for you.
fre55die
Message 2 of 3
Hi @fbeglis  You are in the queue for a member of staff.
To speed up the process could you please ensure that your personal information is up to date in your profile.
Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
