My You-view box will not record
3 REPLIES 3
Hamish Turner
My (relatively new) You-view box has been failing sometimes to record programs but ion the last 24 hours it has always failed to record any program.  Whenever I initiate recording either of a playing program or scheduled from the Guide, I get a "Recording failed" message at the MYTV screen.  Off air playing is working fine, so not obviously the antenna and already recorded programs play back fine also on demand over the internet is OK. I have no reason to think that the machine's software isn't up to date. What else is there to try?
J K H Turner
Have you tried a soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart. Alternatively, you can turn off from the back and power back on.
If this doesn’t work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
Hope it works but if not then please let us know and I’ll flag for further assistance.Hi,
Hamish Turner
Thanks .  The option for a Factory Reset keep recordings option seems to have worked.
J K H Turner
That's good. If any further issues, please let is know.
