My YouView box stuck on one channel
RaynJan
Message 6 of 6
My YouView box appears to be not working properly. It is stuck on one channel and rebooting comes back to the same channel. The remote has no control (even with new batteries ☹️). Help!!
Ray Levett
5 REPLIES 5
Message 1 of 6
Glad to hear my colleagues are sending a replacement box.
Message 2 of 6
Thanks for your help. It has been confirmed that there is a problem with the box and a replacement is on route. Regards
Ray Levett
Message 3 of 6
Yes thanks, I tried all the resets etc but to no avail. TalkTalk telephone centre confirmed there is a problem with the box and a replacement is on route. Regards
Ray Levett
Message 4 of 6
Have you tried the resets as advised by fr8ys ?
Message 5 of 6
Have you tried to reset the remote?
If that failed have you tried a maintenance reset to the box?
Can you change the channel using the buttons on the front of the box?
Full details of the steps you can take are here
If that does not work please post back
