NOW TV.
PaulP2
Message 9 of 9
Hi. If I subscribe to NOW TV, can I watch it with the TalkTalk box on any telly, or do I need any extra hardware? (I have a Sony TV)
8 REPLIES 8
fre55die
Message 1 of 9
@calcotti
I have aways said that they are complentary service so have both. I have had NOW for at least 5 years !!!
Message 2 of 9
@calcotti
You missed the ROKU ABOUT £23
In your list which I find  the best !!. I find That people that close The Entertainment boost will lose access to any of their recordings on ther boxes and that is appalling !! THERE is no warning that years of Recordings are unavailable if you leave TT ENTERTAINMENT!!!
Message 3 of 9
“Subtitles are not available on any app with Now TV.”
It depends on the device used to access NOWTV. They are not available when accessed through a YouView box but are available on other devices such as a NOWTV stick or Smart TV
https://help.nowtv.com/article/can-i-watch-now-tv-with-subtitles
“Subtitles are available on all supported devices, except for the BT TV Box and YouView box.”
Message 4 of 9
Message 5 of 9
Be aware that watching NOWTV through the YouView box does not support subtitles.
Message 6 of 9
No Problem 🙂
Message 7 of 9
@ OCE_Karl wrote:
NowTV is a separate subscription.  You can watch Now TV on a number of devices, from phones / tablets to smart TV's, and also via the App on the YouView box.
Thanks for the thorough explanations, I appreciate it.
Message 8 of 9
