No Sky boost
methley3
Message 12 of 12
Sky boost unavailable since yesterday Fault YVM102
11 REPLIES 11
Message 1 of 12
I'll swap out the TV box and send a returns bag for the other unit to make sure this is not failing.
Message 2 of 12
It is along way from router to tv.  No problems with router as transmitter powerline connected to router shows Ethernet light,  as before the ethernet light on the receiver powerline comes on in the lounge when i connect Xbox or laptop to it.
Message 3 of 12
It could be the adapters at fault, the Tv box or router, only way to prove either is to try a direct connection to see if this works.  Do you have a longer ethernet cable ?
Message 4 of 12
Hi Problem is Router in hall, TV in lounge?
Message 5 of 12
Did you try the box with a direct connection ?
Message 6 of 12
Hi Karl  Have tried all suggestions, no change.  Also missing parts of the Guide facility.
Message 7 of 12
Have you swapped the ethernet cable to the box or tested it ?
Is it possible to test the TV box direct to the router to see if it is working with a direct connection etc ?
Message 8 of 12
Hi Karl Have connected my X BOx to the powerline and the ethernet light comes on.  Tried a full reset on YouView box still no ethernet light .
Message 9 of 12
Try the powerline adapters in different sockets.
you can also put the adapters side by side in a double wall socket whilst these are paired, then put them back in their original location.
Message 10 of 12
Hi The problem appears to be no Ethernet light on the powerline connected to the box, the ethernet light is showing on the router end.  Have bought a new set of powerlines but same problem?
Message 11 of 12
Are you still seeing this error ?
Is the TV Box direct to router with a cable or via powerline adapters ?
