No channels
Jazzland
Message 3 of 3
I don’t think my Ariel works as not picking up any channels whatsoever do talk talk come out and fix them like sky does?
fre55die
Message 1 of 3
@Jazzland
Just one thought, Freeview have had a massive fire at one of their transmitters and whilst a lot of services have been restored there are still some areas with no coverage, https://www.freeview.co.uk/help/service-updates/disruption-services-bilsdale-transmitter  . See also https://istheservicedown.co.uk/status/freeview-uk just in case.
Message 2 of 3
TalkTalk do not offer aerial services, you will need to contact an aerial installer for this.
Make sure you connect your aerial lead directly to the TV and retune to be sure the aerial is failing.
