No live streaming channels
Johnners1
Message 9 of 9
Hello Karl and the TT Team.
Sadly the error is happening again.
No live streaming channels working (Sky One, Nat Geo, Sky Sports etc) Same erroras before 6023.
Think the service went down between last uesday morning and Wednesday evening. We watched a live channel Monday evening but noticed yesterday that a live stream set to record on Wednesday failed.
All other services iPlayer, ITV Hub and on demand Sky working normally.
I've reset the Youview box and router still no joy.
FYI To save reading all the previous posts. Box and router were replaced at the end of November but made no difference then as the fault was at the exchange.
Below is the link to my original post in November, when it first occured and continued in January.
https://community.talktalk.co.uk/t5/TalkTalk-TV/No-subscripton-channels-since-2nd-November/m-p/24292...
Thank you in advance.
8 REPLIES 8
Message 1 of 9
Sorry this is taking so Long.
I've emailed the network teams to chase this for you.
Message 2 of 9
Hello @fre55die
Sorry for the delay in responding.
The Youview box is connected directly to the router. Our original router and box although tested by an engineer, and working perfectly, have been replaced too. This is a fault that first happened at the beginning of November and took a month to resolve. It went wrong again in January and at the beginning of March. It's a problem at the exchange but every time it happens we have to go through the 'have you reset the router' then 'restart the box' etc...
In the long run may cancel the subscription channels
Johnners
Message 3 of 9
Sorry for the delay. I'll chase this up for you.
Message 4 of 9
Hi @Johnners1
Just one thing which doesn't seem to have been asked, Is your box connected directly to the router by ethernet cable, or via Power Line Adapters ?
If this has helped and solved your problem, please mark it as Best Answer so that staff or others do not spend time looking for alternatives.
Message 5 of 9
Hi Karl and the TT Team.
Obviously more important things going on but a quick update. Still no change.
Message 6 of 9
No Problem 🙂
I've also reset the dataport, so you can see if anything changes, but I don't think it will.
Message 7 of 9
Thank you Karl.
I'll wait to hear what they have to say.
Message 8 of 9
I keep all emails when I raise these issues to networks so I can see what has happened previously and what fixed it etc.
I've raised this back to networks to verify the VLAN ID is still present as this was missing last time.
