on 17-04-2022 08:08 AM
My Huawei Youview box DN372T has no sound. I've swapped HDMI cables and sockets on the TV, checked the settings in the Sound section, ensured the volume is up and not muted and restarted the box but the problem persists. I've checked and there is no sound with live tv, internet channels or recordings.
Any further ideas or is the box faulty?
Thanks,
Dan
on 20-04-2022 09:23 AM
How are you getting on?
on 19-04-2022 10:55 PM
Hi @dansuk
It is probably worth trying a maintenance reset (option 2 keeps your recordings). The problem is that TT are now only supplying the non-recording boxes so I'm scratching my head for alternatives. I did experience this once and this did work in my case for some reason. This re-installs the operating system so fingers crossed.
https://support.youview.com/youview-box/box-and-remote/using-maintenance-mode/
on 19-04-2022 10:07 PM
Unfortunately no joy with a different lead or toggling the sound settings. I'm wondering if the box is faulty.
on 17-04-2022 06:27 PM
Hi @dansuk
Do you have an alternative HDMI lead to try?
You could also try Blue button on remote > up to Settings > Picture and Sound, try toggling both the HDMI Sound and the S/PDIF Sound to the alternative surround/stereo settings.
