on β19-05-2018 11:28 PM
Nothing wrong with my internet/broadband/box/cables blah blah blah.
Appatently I just need TalkTalk to re activate my entertainment package again. Been waiting since Thursday. Iβm sure you wonβt hesitate to collect the direct debit for this service which youβre not supplying π‘
on β21-05-2018 08:22 AM
Hi Kazstar1
If you can answer the questions raised by fr8ys, that will help.
Also please add your home phone number to your Community Profile.
β20-05-2018 10:51 AM - edited β20-05-2018 11:04 AM
So we can help or raise to an OCE to look into, what steps have you tried?
Have you run a speed test to confirm you have the minimum speed necessary for the boost channels? You need 5mbps minimum otherwise the channels can dissapear (https://help2.talktalk.co.uk/tv-box-broadband-connection).
Have you tried rebooting your router and then retuning the channels?
Have you tried a soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart. Alternatively, you can turn off from the back and power back on.
If this doesnβt work then try a YouView Maintenance Reset?
You will then need to reset your personal settings (such as parental controls / RF loop through / Surround Sound etc.) and also reset your scheduled recordings (might be worth taking a note of future recordings before doing this so you donβt miss any).
Hope it works but if not then please let us know and Iβll flag for further assistance.
