No subscription channels
irisjean
Message 7 of 7
I have just switched to talktalkTV and fibre broadband and while broadband is ok I have lost all subscription channels? They worked for the first 2 weeks.
When I try and watch sky one for example I get taken to a page saying i need to set up a subscription to watch i.e. take out a boost. I signed up for entertainment boost and this is still showing on my account page so i am puzzled as I am paying for a service that my tv box won't let me watch!
I did call the helpline and I think I was told to wait 72 hours but am confused as I am not technical. My son has said it must be an issue with the system verifying my subscription over the braod band connection?
I was hoping that perhaps you could help solve this issue or at least help explain what the problem is?
6 REPLIES 6
Message 1 of 7
Hi @Jodielee
Could you please start your own thread for support as each problem is individual and needs investigating separately.
Could you please also ensure that your community profile includes your PHONE NUMBER as OCE's will need this to tie up your screen name to your account. (click on your avatar to view the information > Settings > Personal information, then scroll to the bottom of page and click save)
Jodielee
Message 2 of 7
That has happened to me,the exact same problem & wonderd if yours has been fixed yet,I've had the problem since March 27 and talk talk still not fixed it
?? jodie ??
Message 3 of 7
Did you set up the channels, any further problems ?
Message 4 of 7
Hi Karl
Thanks for the reply, due to lots of confusing telephone calls I forgot to check here!
I will try setting up the channels again later and ley you know
Message 5 of 7
Hi irisjean
I'm not seeing any issues with your connection.  There has been some work recently to migrate some TV content to a new platform.
If you follow the on screen steps to set up the channel, does this then allow the channel to work.  you would not be charged twice for the channel, this will just allow the TV box to check the subscription info in the TV database.
Please follow the steps then tell me if the channel works, if it remains the same or there is a different error message or just a blank screen when switching to channel 301 (Sky 1).
fre55die
Message 6 of 7
Hi @irisjean
I have escalated this to OCE support and they will reply here.
Could you please ensure that your community profile includes your PHONE NUMBER as OCE's will need this to tie up your screen name to your account. (click on your avatar to view the information, Settings, Personal information, then scroll to the bottom of page and click save)
