Now TV Channels
KingofLimehouse
Message 5 of 5
I'm having problems accessing the NOW music channels. These used to work at my last flat fine - but for some reason ever since I've moved I can no longer pick them up on my talk talk box. It is just the NOW channels that appear to be a problem - every other channel is working OK. Does anyone know why this might be? Thanks in advance.
4 REPLIES 4
Message 1 of 5
@KingofLimehouse
If doing a re-tune. Unplug the aerial first, then tune without the aerial connected. (It will not find any channels but, will clear the TV memory.) Then tune again and all of the available channels should be found.
KingofLimehouse
Message 2 of 5
Thanks all - that's helpful to know at least! Still unusual to see I'm missing that one in particular. How odd. I'll try retuning soon and see if that gets me anywhere.
Message 3 of 5
As fre55die advises, there are limited options for music channels via the box.
fre55die
Message 4 of 5
Hi @KingofLimehouse
There currently only seems to be the Terrestrial Channel 076 NOW 80's. I'm sure that there used to be more but, they've possibly closed down or been taken over. Is this what you mean? You will need an active TV aerial for this. see : https://en.wikipedia.org/wiki/Now_80s
