Now sports Membership
Marktech0
Message 3 of 3
Hi, Could any one tell me if the upgrade to NOW sports membership is stream in SD or HD , if it is SD can you upgarde to HD.
Message 1 of 3
Hi Marktech0
ferguson is spot on as usual. The boost can only be added from within your Now TV Account, but sometimes they have deals for the boost.
Message 2 of 3
It is 720p, so somewhere in between! You can buy a NOW Boost for £3 a month which gives you full 1080p HD and also adds Dolby Surround Sound, plus you can also use up to three devices simultaneously, rather than the usual two.
