on 19-08-2021 12:04 PM
I can't get not tv app to work on my record box
on 19-08-2021 12:37 PM
OK, but the apps should be accessible on your other box.
on 19-08-2021 12:30 PM
We use the record box lots so we would be losing out I think we will have to look in to sky now then thank you
on 19-08-2021 12:21 PM
The recording box you have does not support the Now TV or Amazon apps.
We can provide a box that will support the apps however this will not be able to record as TalkTalk no longer provide a recordable box.
Would you like me to send the lite box ?
