on 10-06-2021 02:07 PM
When watching on demand TV via the Talk Talk box the feed / picture keeps freezing it does not matter if BBC, ITV, All 4 etc. Had a long live chat (1h 45m) with an agent, who basically got me to do a Factory Reset on the box, which I did. When I went back to the agent saying that it had not sorted it, the chat was ended. Without any comment, I've printed out the transcript of the chat (6 pages), but where do I go from here?
on 17-06-2021 12:41 PM
You're Welcome 🙂
on 17-06-2021 12:22 PM
Hi Karl
All seems to be working OK at the moment, many thanks for your help.
Steve
on 15-06-2021 04:00 PM
No Problem 🙂
on 15-06-2021 03:39 PM
Thanks Karl
They arrived this afternoon, will let you know how we get on.
Steve
on 14-06-2021 09:08 AM
Hi Steve
I've a replacement set of adapters on the way to see if this helps.
on 12-06-2021 08:36 AM
Hi Karl
OK have re paired the adaptor's, it's better but not right. Last night watch a 2 hour show which froze after about 10 mins, could not do anything (FF, Rev etc) so hard to cancel and restart from beginning, it did buffer a few times. I pulled the plug board out so I could see the adaptor that is hard wired to the TV box and the powerline light was mostly amber (either steady or blinking) and only very occasionally going green, again either steady or blinking. I checked the one up stairs to the router and that always seemed to be green (well at least when I looked!)
Steve
on 11-06-2021 03:48 PM
Will have a go at that, will let you know.
Steve
on 11-06-2021 10:24 AM
Try resetting the adapters and then pair them up and see if they still buffer. If they do, we could try swapping them out for a new set.
on 11-06-2021 10:11 AM
They are the first one in the block, re locating not possible due to location of PC / Router and the TV.
It has been fine for years its only in the last few weeks it has started to give problems.
on 11-06-2021 09:19 AM
Extension blocks will degrade the performance of the adapters and where possible these should be direct into wall sockets. If used in an extension they should be in the first socket nearest the cable.
Is it possible to try relocating the adapters to see if there is improvement.
on 11-06-2021 08:58 AM
Hi Karl
No the adapters are in extension leads (which was where your engineer put them originally), everything else seems OK.
Will add phone number.
Steve
on 11-06-2021 07:05 AM
Are the adapters direct into wall sockets ?
Is general internet ok to other devices etc ?
Can you add your home number to your 'Community Profile'
on 10-06-2021 05:13 PM
Hi Karl
Powerline adapters
on 10-06-2021 02:35 PM
Hi Steve,
Is the box direct to the router with a cable or do you use powerline adapters ?
