Picture break-up on Sky Sport boost
Penfoldbin28
Message 35 of 35
I have had an issue with the Sky Sports boost for quite along time now.  When initially turned on the picture breaks up and the only way to correct it is to reset the router then it seems ok until the next day then same procedure all over again.
I think it is a router problem as I have multi-room and the same issue occurs on the the 2nd set top box.  Unfortunately I lost the sky boost, well not lost it but it kept saying that it needed addind or something similar!  You couls see the channel it just didnt come on!  IPC6017
I yesterday received a new set top box for box 1 and again the picture is breaking up! Just what is the answer and the way forward.
This morning I reset the multli-room box to factory setting and eventually the Sky boost has re-appeared but the feed is still breaking up!
Help!
David
34 REPLIES 34
Message 1 of 35
Completely all my fault as somehow I turned off the powerline adapter earlier today and didn't realise it until you mentioned that it could be a problem with the adapter.
I am sorry for being incompetent in this case!
Whatever the Openreach engineer did on Wednesday has certainly helped with the reception on the Sky boost too so hats off to him as well!
David
Message 2 of 35
I think the problem may be mine as somehow I managed to turn off the powerline adapter but now cant get it back on.
Sorry about this!
David
Message 3 of 35
I keep getting that 500/501 error too, obviously a blip with the forum servers at the moment to add to the fun!
Have you tried a direct connection  by ethernet cable from box to router? I realise this may not be practical in the long term, but just for testing purposes.
Message 4 of 35
I keep getting 500 Internal Error when I try to respond to you!
Powerline connectors.  All been switched off and back on again.  Still no boost and also I cant get last seven days tv or apps
Match nearly over what a waste of time this is - very annoyed
David
Message 5 of 35
OK, apologies if we are going over old ground, but how is the box connected to the router? Could it be a powerline issue?
Message 6 of 35
Yes we've even had Openreach out last week which appeared to have resolved the initial problem but now there's now connection between the router and box.  At one point there was no channels available at all.
David
Message 7 of 35
Has it been working OK since OCE Karl last responded a month ago? Did you reply to his PM?
Message 8 of 35
No Sky boost or apps now.  Really annoying as we wanted to watch Leeds v Arsenal.
Very annoying!
David
Message 9 of 35
I'll drop you a PM with the info required.
Message 10 of 35
The problem needs sorting so if that is your recommendation then I suppose that's what needs to be done.
I await further details.
David
Message 11 of 35
The sync speed is at 39mb, this is the agreed speed between the router and exchange.
Actual download speeds will be a bit lower and should average around 32-35 but this is also dependant on the device used and the speed test used.
The next option would be to progress towards an engineer.
Message 12 of 35
Sorry i mean I've plugged my laptop into the router
David
Message 13 of 35
Hello Karl
I've plugged it directly into the router and the checks I've done range from 14.5 to 33mb.  Most were top 20's to early 30's but non reached what you achieved.
We had to reboot the router several times yesterday whilst watching the Sky Sports channels and this morning there is still interference on Sky Sports - I haven't rebooted this morning.
David
Message 14 of 35
Sync speed is showing at 39mb, was the last speed test wireless or wired ?  It is important to run the test wired to get an accurate result.
Can you test the speeds via the TalkTalk speed test or alternatively try : Sam Knows Speed Test
I've found this to be relatively accurate.
Message 15 of 35
Hello again
Picture was ok earlier today but turned it onto Sky 402 and picture now breaking up.
I've put the splitter into the test socket which rebooted the router.  I thought that this would reset the picture but it didn't so I connected the ethernet cable from the router to the set top box and it is still breaking up.  On the Which? speed checker the download speed was 13.4mbps
David
Message 16 of 35
Hello Karl just a quick update.
Yesterday the picture didn't break up at all but when I've checked this morning the picture was breaking up!  I've now rebooted the router and it seems ok!  I forgot to do the check on the test socket so I'll try and remember this next time it happens.
For a few days I've also had a problem with a Wi-fi connection to my laptop in  the lounge and conservatory as it wouldn't connect unless I was quite close to the router - this isn't a new problem but again is rectified on most occasions as this morning by a router reboot.  Oddly enough other devises like mobiles and a tablet are ok and keep the connection.
David
Message 17 of 35
OK, No Problem 🙂
Message 18 of 35
Oops sorry I'm wrong I may have a test socket - I will investigate and get back to you.
However the picture is fine at the moment
David
Message 19 of 35
Hello again, I checked both set top boxes this am and the picture was good and not breaking up.
I'm not sure what you mean by test socket as there is only the standard phone socket in the house so I use the splitter for phone and broadband.
David
Message 20 of 35
All tests are clear, no errors showing on the line, every test I've ran is clear.
Can you connect the router directly at the 'Test Socket' and see if this makes any differance.
After this, an engineer may be required to investigate further.
