on 21-02-2020 02:57 PM
Hi. I'm new to talk talk and have a few issues.
1. My HD reception isn't great and breaks up regularly. The same HD channels on freeview are fine and it's the same aerial.
2. All subscription channels are unwatchable. continually breaking up, dropping out and pixelating. For some reason it's much worse after dark
3. The you view box is really glitchy. Eg: you press the remote to scroll down and have to wait 30 seconds for the screen to respond.
on 27-02-2020 12:56 PM
No Problem
on 27-02-2020 12:45 PM
on 27-02-2020 12:43 PM
OK, I'll get this out to you now.
on 27-02-2020 12:31 PM
on 27-02-2020 12:29 PM
Would you like to try a different model router to see if this gived better performance.
on 27-02-2020 09:44 AM
27-02-2020 09:41 AM - edited 27-02-2020 10:04 AM
All usual line tests clear, and syc speed at 80mb, so all looks ok from here. You can also try swapping the ethernet cable or try a different port on the router to rule these out.
on 27-02-2020 08:56 AM
on 27-02-2020 08:48 AM
You could try a signal booster for the terrestrial channels. With regard to the internet channels, is the TV box direct to the router with a cable ? Check the home phone has a clear dial tone, so no crackling on the line etc. Do you have any broadband issues, slow speeds, dropping coections etc ?
on 27-02-2020 08:42 AM
on 27-02-2020 08:38 AM
Do you have any aerial splitter in place etc. Looking at the box remotely, the signal strength for the usual channels, BBC / ITV etc is only at 35. This is very low and will cause issues.
on 26-02-2020 02:46 PM
on 25-02-2020 06:39 AM
No Problem.
we're here when you need us.
on 24-02-2020 05:57 PM
on 24-02-2020 08:33 AM
Please let me know if the reset helped.
on 21-02-2020 06:42 PM
I've already tried the hdmi cables. No good.
'll try the reset.
21-02-2020 05:28 PM - edited 21-02-2020 05:36 PM
Hi @Andy clare
Try a new or different HDMI cable as it could be a connection problem.
Is the TT box connected directly to the router by cable or are you using Power Line Adapters ?
If this doesn't improve things, I should try a Maintenance Reset option 2 as follows :
Turn the box off, then unplug power lead for a couple of minutes.
Re plug in power .
Ensure the YouView Box is switched off and is currently connected to the router (the YouView Box will require an internet connection).
Power on YouView using button at the back of the YouView Box.
Start YouView using the power button on the YouView Box front panel and then quickly press and hold both the + and – buttons on the front panel. If you haven’t pressed the buttons together by the time 'YouView Waking Up' is displayed, or you see the 'YouView please wait...' message then try again.
Let go of the + and – buttons once the 'Huawei – Maintenance Mode menu' is displayed.
The + and – buttons on the front panel will navigate the menu. Keep pressing the – button until 2 “factory reset keep recordings” option is highlighted. If you go past the option, simply press the + button to navigate back to the option.
Press the power button on the YouView Box front panel to select the option. This will bring up some information and ask 'Do you want to proceed?'. Press the power button again to confirm.
The YouView Box will now show a progress bar as it downloads software from the internet and installs on the YouView Box. This may take several minutes. Once complete, the YouView Box will restart.
Once the YouView Box restarts, the YouView Box will show the initial setup wizard. You will need to run through the setup wizard including tuning the channels.
You will then need to reset your personal settings (such as parental controls / ANTENNA OUT / Surround Sound etc.) and also reset your scheduled recordings (might be worth taking a note of future recordings before doing this so you don’t miss any).
It is also a good idea to restart your router once you have done this !!
IMPORTANT !!!!!!
