Picture keeps breaking up
joanna258
Message 5 of 5
My picture keeps cutting off  to a black screen and coming back on a few seconds later or sometimes minutes at a time.  You can't watch any programmes and its getting worse.
I thought it was the power lead which was faulty but have tried a new one and it still doesn't work so I think it must be a fault with the actual you view box.
4 REPLIES 4
Message 1 of 5
Hi joanna258
Can you please add your home phone number to your 'Community Profile' so I can pick this up for you.
Gliwmaeden2
Message 2 of 5
For staff to follow up, @joanna258, please complete your community forum profile details. This is so they can identify your account and your address in case you need replacement equipment etc.
It's important to add your Talktalk landline number by going via your avatar/name; settings; launch profile wizard.
joanna258
Message 3 of 5
I've tried all these but still not working
Message 4 of 5
Have you tried a soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart. Alternatively, you can turn off from the back and power back on.
If this doesn’t work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu. You will lose your recordings but you may be asked to do this before the OCE look at other alternatives.
Hope it works but if not then please let us know and I’ll flag for further assistance.
