Pixelating TV Channels
jaysee1
Message 3 of 3
For the past  2 weeks my tv picture has been pixellating when viewing ordinary channels via my Youview box. This does not occur when I watch other TV's in my house which are not connected via a Youview box.
Also when I watch Sky Sports via the Youview box, this does not occur.
I have re-tuned the box  but no different. Any ideas??
Message 1 of 3
Hi jaysee1
Did you follow the advice from fre55die ?
Are the channels still pixellating ?
fre55die
Message 2 of 3
Hi @jaysee1
Have you tried using an alternative aerial lead as it sounds like it is picking up interference. Also try a retune without aerial plugged in ( this will clear the memory) then plug in aerial and retune again. YV button on remote > Settings > TV channels.
