Pixelation
Tripleh
Message 7 of 7
I have had pixelation problems on certain channels for years, but just switched to my tv free view when it got bad. I recently bought a new aerial and the engineer showed me why I get pixelation. There are 2 transmitters in my “range” one of them is in the lower range when tuning my TT box but the stronger transmitter is in the higher range. So when we tune the TT box it finds the lower range transmitter and not the better one. He said it’s an inherent problem with your box. Can you help please?
6 REPLIES 6
Message 1 of 7
You could also take a look in the 800 range and see if the box has sorted the higher strength channels here and use these. Not ideal, but as mentioned previously clearing the memory with the aerial out and then fully retuning, should of helped, but I notice you said you put the aerial in whilst tuning, so it may still be holding a memory trace.
Message 2 of 7
You could try a signal booster, but other than that, nothing else I can suggest.
Tripleh
Message 3 of 7
Hi Karl, that is my case, so how do you suggest I overcome the pixelation? Thanks
Message 4 of 7
It is not possible to manually tune or select a transmitter on the youview box when tuning for freeview channels.  The box will usually pick the best signal at the time, but issues such as this may occur when you are equidistant from 2 transmitters.
Tripleh
Message 5 of 7
Hi fr8ys
the aerial actually goes to the box first. The engineer even tried a factory reset first then retuned but the box still plays the weaker channels first. He tried leaving the aerial out and putting it back in half way through tuning and that didn’t work. He said when tuning it doesn’t show anything only a progress indication. Thank you for your reply though
Message 6 of 7
The box should pull in the strongest signal.
Does the aerial go to the TV first or the Box first? If the TV try swapping the cables round so the aerial goes to the box first. If you haven't done so, turn the antenna out function of the box to On, so the signal gets through to the TV.
Then remove the aerial from the box and perform a retune. This will result in 0 channels, but will clear the box of any residual memory.
Reattach the aerial and retune again and you should then pick up the stronger signal.
Let us know how you get on.
