Play button stuck on remote control
Chris46823
Message 2 of 2
Got a fairly old TalkTalk YouView remote control; works fine expect for the play button often doesn't work (particularly frustrating when fast forwarding and trying to hit play to stop it at the right point).
Is this something that I can fix myself by taking it apart?
1 REPLY 1
Message 1 of 2
Hi Chris,
I'll get a replacement remote out to you.
