Poor Youview Freeview signal
Hiltophouse
Super Duper Contributor
Message 8 of 8
Been having some Freeview picture issues over recent weeks and only just got around to trying to troubleshoot.
It seems if I discconect the RF pass through cable the picture/signal is more stable. Anybody know why this would be the case and I can avoid it?
I want to pass the aerial signal onto the TV tuner so not wanting to leave it out.
7 REPLIES 7
Message 1 of 8
ok, No Problem 🙂
Message 2 of 8
Thanks Karl, I'll bear with it for the moment (as have lots of recordings!), but it gets worse I'll get back in touch.
Message 3 of 8
Hi Hiltophouse
We could swap out the box for you, but this would mean losing an recordings.
Message 4 of 8
@Karl-TalkTalk I've tried another cable and I have the same results. If get picture breakup, if I remove the cable for the pass through it resolves the problem.
@fre55die Yes, pass through is enabled
fre55die
Message 5 of 8
Hi @Hiltophouse
I know that this sounds obvious but have you enabled the RF PASSTHROUGH in settings ? YV button > Settings > Picture & Sound >Antenna Out . As by default this now sets to off.
If this has helped and solved your problem, please mark it as Best Answer so that staff or others do not spend time looking for alternatives.
Message 6 of 8
Hi Hiltophouse
Are you able to test another cable from the RF out incase there is any fault or internal break with the cable that could be causing disruption ?
Message 7 of 8
I will ask one of TalkTalk's OCEs to pick your thread up and investigate it for you.
The forum is not real-time 24/7 support, so depending on how busy they are & how many are working at any one time, this can take 24 - 48 hrs (excluding weekends & Bank Holidays). Alternatively, you can call the call centre or use online chat. The posts are responded to in time/date order, oldest first. So the fewer entries you make on your thread now, the sooner they will pick it up.
Otherwise, TT will not be able to tie up your forum username to your broadband account. Only you & TalkTalk have visibility of your details.
