Poor tv reception via the you-view plus box
celynen
Message 4 of 4
Hello, I am having problems with my tv picture when viewing via the youview box with lines of missing pixels and flickering. This also affects my recordings, which are un-watchable.
I have tried retuning the box and I have also replaced the cables, but the problem persists.
If I connect the tv directly to the coaxial aerial cable the picture is perfect.
Please can you suggest what I can try to overcome this problem?
3 REPLIES 3
Message 1 of 4
Pleased it worked.
celynen
Message 2 of 4
Thanks for the reply.
I tried your first suggestion, retuned without the cable, then with, and the tv picture is back to normal. I haven't yet tested recordings.
Regards John.
Message 3 of 4
Try retuning the box with the cable out. You will get no channels but it will clear any memory the box may hold.
Then try tuning again with the cable in.
If this does not work, there are more drastic steps you can try as below, but hopefully this will work.
If the following fails then wait for an OCE next week to consider next steps. If you are eligible for a new box, please note TalkTalk no longer provide recordable boxes, so trying to recover the box is your best option if recording is important to you.
Have you tried a soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart. Alternatively, you can turn off from the back and power back on.
If this doesn’t work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu. You will lose your recordings but you may be asked to do this before the OCE look at other alternatives.
Hope it works.
