Power Adapter problem
Oscarchops
Message 6 of 6
My TalkTalk powerline adapters has stopped working.  I have followed all the suggestion in the guide but nothing works. I've had them for 3 or 4 years without a problem, but they have suddenly packed up. I've tried everything including the recommended 'reset button'. Can anyone suggest what I can try next.
I cannot get through to anyone to talk to.
5 REPLIES 5
Message 1 of 6
You're Welcome 🙂
Message 2 of 6
That's fantastic. I was so dreading spending hours on the phone to sort it out.
Thank you.
Message 3 of 6
Hi Oscarchops
a set of adapters are on the way.
Message 4 of 6
Thanks for the info.
Info added to my profile.
fre55die
Message 5 of 6
Hi @Oscarchops
VERY IMPORTANT FOR SUPPORT !!!!!!
Could you please ensure that your personal information is up to date in your profile INCLUDING your registered landline number
Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info.
This is purely so that the staff can tie up your details and trace your account as this is not possible from just your screen name.
Thank you
If this has helped and solved your problem, please mark it as Best Answer so that staff or others do not spend time looking for alternatives.
