Power Line Adapter (PLA) is making a loud buzzing noise!
sdelasal
Message 1 of 9
This setup is at my 84yr old mothers place - PLA's are used to get the wifi into the lounge from the router in the front of the house. The setup has worked pretty well. However, now one of the PLAs is putting out a loud objectionable buzzing noise.  How do I get a replacement unit?  Is it safe to leave it plugged in and active in this state?  thanks. Steve
8 REPLIES 8
Gliwmaeden2
Message 2 of 9
Staff will be back on here during business hours,  @sdelasal.
Message 3 of 9
Hi Steve
Please check the phone number you have put on your 'Community Profile' , it is to an old disconnected account.
Message 4 of 9
profile number updated.
Message 5 of 9
A set of replacement adapters are on the way.
Message 6 of 9
great, thanks - until replacement arrives,  is it okay to leave the buzzing one plugged in?
Message 7 of 9
Check the adapter is not getting hot.  If it's not then it should be ok to use until the new ones arrive.
Message 8 of 9
thanks for that. They arrived and have been installed so normal service has resumed.
Message 9 of 9
Excellent.  Thanks for letting me know.
