Power line adaptor not lighting up.
NEWbrain1
Message 7 of 7
One of two power line adaptors is not showing any lights. I have moved the adaptor to another socket but no joy. If I press the reset button the middle light shows green for a couple of seconds before going out. Help please.
6 REPLIES 6
Message 1 of 7
Hi Handyman15
If you start your own thread (new message), wed love to help.
Weve found that posting in someone elses conversation makes it harder to follow when looking for an answer.
Its easier and quicker if we can chat with you in a single thread, if you start your own thread, that will keep our community organised and help others with a similar problem.
Check your home phone number or account number are also added to your Community Profile as that will really help us to find your details quicker.
Handyman15
Message 2 of 7
Hi have got the same problem as one of my adapters isn’t lighting up and can’t access anything. They are the Huawei PT200AV and I read somewhere that these were used at first then changed.
any help appreciated
Roy
Message 3 of 7
Hi NEWbrain1
I'll get a set of adapters out to you.
Message 4 of 7
Hi @NEWbrain1
I have escalated this for OCE support for you and they will respond here.
How old are they?
VERY IMPORTANT
Could you please ensure that your community profile includes your PHONE NUMBER as OCE's will need this to tie up your screen name to your account. (click on your avatar to view the information > Settings > Launch Profile Wizard,put your phone number in box, then scroll to the bottom of page and click save) Only you and the OCE's can see this information BUT, without it they cannot access your account information.
If this has helped and solved your problem, please mark it as Best Answer so that staff or others do not spend time looking for alternatives.
NEWbrain1
Message 5 of 7
Thanks, but the power light on the plug is not showing.
fre55die
Message 6 of 7
@NEWbrain1
If you reset the plug it also needs re-pairing.
https://community.talktalk.co.uk/t5/Articles/Fix-a-problem-with-your-wireless-Powerline-adapters/ta-...
