on 10-05-2018 03:13 PM
Our TalkTalk powerline adapters are not working. The little house in the middle is not litup and so we have no internet connection. I have unplugged them and started from scratch & repaired them and reset them and they are still not connecting to the internet. What should I try next?
on 21-05-2018 08:00 AM
glad these are working for you now.
on 19-05-2018 07:53 PM
Hi Karl
Thanks a lot -have managed to get them working now. Wouldn't connect to each other in same room- so moved the extender & lo and behold ....it worked. Thanks again
Rusty2
on 17-05-2018 03:40 PM
Hi Karl
Thanks for sending a new set. I am having some problems setting them up but I will persevere following all the instructions. All the lights are OK apart from the WiFi one on the extender. Have tried pressing the pairing button and the WPS button and it started flasshing but just sits there flashing forever. Will start again from scratch & if that doesn't work will try the reset.
Thanks again
Ann
on 14-05-2018 07:19 AM
A replacement set are on the way.
on 11-05-2018 02:38 PM
I have now added my home phone number to my profile.
on 11-05-2018 08:24 AM
Can you please add your home phone number to your Community Profile so I can locate your details.
If unsure of your number, simply dial 17070 from your land line phone and this will confirm the number for you.
Please reply when this has been updated.
