on 16-07-2020 10:25 AM
Is it possible to buy additional receivers for the Powerline system?
on 17-07-2020 07:23 AM
If you start your own thread (new message), we’d love to help.
We’ve found that posting in someone else’s conversation makes it harder to follow when looking for an answer.
It’s easier and quicker if we can chat with you in a single thread, if you start your own thread, that will keep our community organised and help others with a similar problem.
on 16-07-2020 10:50 PM
Hi Karl. I noticed you had a recent exchange with a TT customer about TT D-Link Power Adapters 'dropping out' so thought I'd post my query here as I couldn't find that again.
I have a similar issue but it's not that one doesn't work: it's that it just stops working overnight (every night), so - for the past few months - it needs to be reset every morning (the only light displaying is the right-hand network one, and it is flashing, not solid green). Sometimes it can take multiple attempts - by turning it on and off - to get all three lights to show green. Once this is done, the Power Adapter - which feeds my YouView box - then remains on and functioning for the remainder of the day (so typically, for at least another 18 hours), but always returns to a single flashing green light the next morning. Weird, huh?
Once, at 4am, I came downstairs and noticed the entire Power Adapter had no lights flashing - which may explain why there is then a single light flashing at 7am... - but I can't understand what would cause it to shut down between, say, midnight and 4am every day (no other appliances are affected). I have swapped the mains socket that the Power Adapter is plugged into and this makes no difference. I have also swapped Power Adapters (the other one is connected to my router). Any suggestions on how to fix this, or would it be better to try new Power Adapters.
Thanks,
AK
on 16-07-2020 03:22 PM
The adapters are both transmitter / receiver, and you can have more than one on the circuit.
on 16-07-2020 03:02 PM
Thanks, Karl, is it possible to have more than one 'receiver' on the circuit at a time? Can I just get the 'receiver' part?
on 16-07-2020 11:12 AM
Take a look here : https://accessories.talktalk.co.uk/
