Powerline adapters not pairing
jenngalla
Message 6 of 6
I have been through all of the troubleshooting advice for pairing my powerline adapters, but nothing works. I am also unable to reset factory settings, as there is no reset button on my adapters, only a pair button.
I am trying to pair the 2 adapters 1 metre apart, so distance should not be the problem. Please advise!
Jennifer Leyland
5 REPLIES 5
Message 1 of 6
Hi jenngalla
Can you add your phone number to your 'Community Profile' so I can locate your details.
Message 2 of 6
Hi Karl,
I did as you said and placed both powerline adapter and receiver next to each other in the same socket. They didn't pair automatically so I pressed the transmitter pair button for 2 seconds. Then I held down the receiver button and it flashed Amber, but did not remain solid. I continued to hold the Button down and it flashed Amber again but once more did not remain solid. The green power light was solid on the receiver when I removed my finger.  According to the instructions I should press the reset button, but there is no reset button on either transmitter or receiver. Help!
Jennifer Leyland
Message 3 of 6
Extension leads can weaken the signal so we always advise to plug directly into the wall sockets where possible.  Are you able to try these in a double wall socket ?
jenngalla
Message 4 of 6
I had the adapters plugged in next to each other, 1 was plugged into an extension lead and I placed it next to the other which was directly into the wall.
I ordered new powerline adapters a few months ago because I also had problems with the previous ones.
I thought maybe the issue was our broadband speed, so we upgrades recently, but it doesn't seem to have made a difference 😕
Jennifer Leyland
Message 5 of 6
Can you see if they will pair side by side in a double wall socket, then place back in their original positions ?
also, how long have you had these adapters ?
