on 31-03-2021 09:31 PM
Hello, following TalkTalk Software Update 60.48.91 & 72.48.91 / 3.7.54 , the latest update the following changes have occurred.
1. The picture size has changed.
2. No sound.
Our Youview model is the DN360T. We connect to the TV via HDMI and have an external speaker system via optical cable. We have tried a factory reset without success.
Everything was working fine before this mornings update. Has anyone else had the same issue?
Answered! Go to Solution.
on 02-04-2021 06:09 AM
Hi grumpydraws
I'm glad to hear that this is working ok now 🙂
If you do experience any further issues then please let us know.
on 01-04-2021 05:08 PM
Pleased its all sorted.
If you haven't done so, could you update the YouView forum too please to save anyone there giving advice. Many thanks.
on 01-04-2021 04:56 PM
Hi Debbie, thank you for your reply.
Strangely, we just turned off the Youview box overnight as we would normally do leaving the router switched on. Believe it or not, everything was back to normal when the box was powered up this morning. Really not sure how the picture and sound has rectified itself as we could not reconfigure it yesterday, whatever we tried.
We were linking the problem to the update as the picture and sound changed after the request to update the software was accepted.
Very strange!?
on 01-04-2021 04:53 PM
Hi Steve, thank you for your reply. Our Youview box is connected directly to our router.
Very strange!?
on 01-04-2021 06:12 AM
Hi grumpydraws
Please can you try another factory reset?
on 31-03-2021 10:49 PM
I doubt it otherwise it would have been reported by others here and on the YouView forum (l notice you have posted on there too).
How is your box connected to your router? Direct or via powerlines?
I'd suggest trying rebooting your router, re-pairing powerlines if you are using them, and trying a factory reset again.
Hopefully it will restore your box but if not, you are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile including your TalkTalk landline phone number so your account can be traced. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
Thank you
