RE: TV Box on powerlines
hosay299
Message 9 of 9
HI all just after some advice am looking at making the tv box hard wired just would like to know would that be worth while as the power line do see to loose internet at times do not know if it is the box or the p/l`s causing it
as the box is in the room below where the router is. as the master socket is upstairs
Would u do it and would it work ok on a a long Ethernet cable??
Hope that help Regards Joe
8 REPLIES 8
Message 1 of 9
@ferguson yes I know just want am looking at improvements or changing rooms around.
Lockdown has made things change ways in different areas
Thanks for ur help
@ifanyonecan I do not think the issue is to do with wake up as it works fine just disconnects on player sometimes on amazon.
I also have tp extender for wifi that works fine for devices.
ifanyonecan
Whizz Kid
Message 2 of 9
Have you tried using the Tp-link utility and turning off Power Save Mode on each plug as sometimes they forget to wake up. You may have to turn off your antivirus to use the utility as it won't find any plugs on my PC with it turned on.
Message 3 of 9
Hi Joe, you can get better quality DSL cables than the usual in-the-box types, but they will still invariably degrade the signal over distance. What reason do you have for relocating the router? A lot of this is trial and error, so at the end of the day for the sake of a few quids worth of cable just try it out and see what happens!  🙂
Message 4 of 9
@ferguson just a quick one would the broadband router be fine with a long dsl cable as in i am thinking of moving the router to the back of the house??
Message 5 of 9
@ferguson yes will do might be having all the pc stuff near each other.
same the boxs are not going to be up-dated to wifi ones. save the issue then for most of the issues.
thanks
Message 6 of 9
Might be worth reaching out to TP-Link for help and advice?
Message 7 of 9
@ferguson Hi yes i have as they are powerlines are tp link. just having a few things looked at as the router is behind my monitor and my pc is next to that so am looking at a move of some sort
as they say have a spring clean!!!!!
thanks for u help
Message 8 of 9
Hi Joe, without a doubt it will be better, direct wired connections always are. The issue is usually inconvenience of course.
Have you checked the powerline adapter help articles?
