Recording Tv Programmes
catfordman
Message 6 of 6
My Talktalk box has stopped recording.
Is this because Talktalk no longer offer this function?  How can I record programmes?
Any help gratefully received as frankly the Talktalk call staff are not very helpful.
5 REPLIES 5
Message 1 of 6
Hi catfordman
That's great news 🙂
Thanks @fr8ys 🙂
Message 2 of 6
Great. Long may it continue.
Message 3 of 6
Hi there
Thanks for the help and so far, so good.  Only got round to trying this today but seems to have worked.  Time will tell but we seem to be ok now.
Message 4 of 6
Hi catfordman,
How are you getting on?
Message 5 of 6
If your box previously recorded, and you have not been sent a replacement box, it should still function.
It may have an issue that you can possibly fix, providing the hard drive is not beyond saving
Have you tried a soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart. Alternatively, you can turn off from the back and power back on.
If this doesn’t work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu. You will lose your recordings but you may be asked to do this before the OCE look at other alternatives.
Hope it works but if not then please let us know.
