Recording and playback problems
chrissf49ers
Message 4 of 4
I am getting a number of recording and playback problems. Various programs fail to record - nothing changed, internet working etc. etc. Recorded programs start playing and sometimes the screen goes black or the picture freezes and sound continues or picture and sound freezes or sometimes a recording will suddenly fast forward by itself.  I have found by switching off the box and back on again the fail to record issue goes away but happens again when it feels like it. I think there may be a fault with the box. Has this happened to anyone else?
3 REPLIES 3
Message 1 of 4
OK, keep an eye on things and see how it goes.
Message 2 of 4
Thanks Karl. As I've already turned the box on and off a number of times, I performed a software reset from the maintenance menu. The box is back up and running but I won't know for some time if it has cured my problem.
Message 3 of 4
try a Youview Maintenance Reset  and see if this helps.
