on 15-06-2021 06:19 AM
Since around a week and a half ago we've been having problems with our TalkTalk box. We can still set programmes to record and they show up in our 'my recordings' section but the play icon next to them is only half red which I assume is meant to mean partially recorded. On trying to play the recordings they don't work, just a black screen.
My mum tells me the look of the UI when attempting to play back the recordings is different, it seems she hadn't seen it before the change that made it stop working. So could there have been some kind of update to the box that stopped recordings from working?
Thanks in advance for your help,
Megan
on 15-06-2021 09:05 AM
Hi MeganK
as fr8ys advises, if the box is still failing, we can provide a lite box for you.
on 15-06-2021 08:45 AM
Hope it works, as if you are eligible for a new box, TalkTalk no longer supply recordable boxes, only the lite box.
on 15-06-2021 08:13 AM
Hi, thanks for the reply. Last week I tried the reset while keeping recordings but that didn't work. I'll try the full factory reset today and leave a reply here if it still goes wrong.
on 15-06-2021 08:08 AM
The change in UI shouldn't have made a difference to recording, but any update can cause issues and can often be cleared by maintenance, much as you would when a PC has issues with a new version of Windows being installed.
Have you tried a soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart. Alternatively, you can turn off from the back and power back on.
If this doesn't work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu. You will lose your recordings but you may be asked to do this before the OCE look at other alternatives.
Hope it works.
