Recording playback freezes
methley3
Message 3 of 3
On my 3rd Youview box this year, common fault is that recordings freeze for about 30 seconds on a random basis. Some recordings fine, others 2 or 3 times in 30 minutes.  Any suggestions.
Message 1 of 3
Hi methley3
try the resets as mentioned, and le me know if that helps.
Message 2 of 3
Have you tried a soft reset? To do this hold the on button down u til the box reboots.
if this does not help, have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
Staff here are looking into box failures, so if you can answer the following, where possible, it will help them in their investigation.
1 Box model/SW version.
2 What channels are being recorded?
3 If these are Boost channels, do they currently subscribe to the boost.
4 If they are Terrestrial channels, what is the signal strength/quality on the channels being recorded?
5 Were these series recordings or episode recordings?
6 Do any recordings work?
If so,
(a) what is the earliest recording made that works (i.e. do recordings made prior to November work)?
(b) Are you able to exit the recording via the Back, Close or Menu keys?
(c) Do ffwd/rwd work, or does a playback bar appear when these or pause keys are pressed?
7 Does a factory reset resolve the issue, or maintenance reset etc.<br
Hope it works but if not then you are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile including your TalkTalk landline phone number so your account can be traced. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
Thank you
